20 Most Recent HEWLETT-PACKARD T790 InkJet Plotter Printer Questions & Answers
2answers
Reset hp t790
In Diagnoses mode EEPROM reset has to do for resetting, Entering the Diagnostics Menu 1. Make sure the product is switched off with the Power key on the side of the Touch Screen Panel, and not with the power switch on the back of the product. 2. Press and release the Power key to switch on the product. 3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel have come on and then press and release one after another Cancel> Home> Help buttons. 4. The 6 buttons on the Touch Control Panel will then blink 4 times; then wait until the product completes the initialization sequence and shows the Diagnostics menu. 5. In the Diagnostics menu scroll to EEPROM reset.. But we strongly recommends that useres are not suppose to do this activities, printer may disturbed all the way...
10/11/2021 1:17:49 PM • HEWLETT-PACKARD... • Answered on Oct 11, 2021
How to turn off web services on a HP T790
You can configure the printer's Internet connection from the Embedded Web Server or from the front panel. NOTE: If an administrator password has been set, it will be required to change these settings. Thus, the administrator can prevent the printer from being connected to the Internet, if desired. ? In the Embedded Web Server: select Setup > Internet connection. ? Using the front panel: press , then , then Connectivity > Internet connectivity. The following settings are available: ? Enable Internet connection: The default value is Yes. Change to No
9/10/2015 4:34:18 PM • HEWLETT-PACKARD... • Answered on Sep 10, 2015
Remove roll from sheet path
This is one of frequent error in this series. as you know two types of media paths 1. roll media 2. Sheet media. In sheeteet media loading area, you can observe 'u' shaped(extremly right side where sheet media sits) plastic mould which paper passes through in it. This palstic mould contains paper sensor to sence the sheetmedia. If this sensor is dusty, printer will treats that sheet path accupied by media. The best method to clean this sensor is to blow pressure air in this sheet path area.bicycle pump is best for this process.. try it...
9/24/2014 5:18:56 AM • HEWLETT-PACKARD... • Answered on Sep 24, 2014
My plotter will just click and wont return
If carriage sits at right side., might be service station jammed, its not releasing the carriage assm..its critical issue., dont force to pull out the carriage, it may damage print heads.. pl contact professionals..
9/23/2014 2:11:26 AM • HEWLETT-PACKARD... • Answered on Sep 23, 2014
2answers
Error 08 11
English please
6/29/2014 6:57:41 PM • HEWLETT-PACKARD... • Answered on Jun 29, 2014
Error 08 11
No communication between the product and the Touch Control Panel Corrective action: Try the following: 1. Check the event log at the EWS support pages to see if there is another SE (for instance 07:10) and troubleshoot the problem more accurately 2. Turn off the product and turn on again, and check to see if the error remains. 3. Upgrade the firmware 4. Check the condition of the USB cable, check it is not damaged or incorrectly connected.Reconnect USB cable (from Engine PCA to the Interconnect PCA or from Interconnect PCA to the Touch Control Panel 5. Replace the USB cable 6. Replace the Interconnect PCA, see Interconnect PCA on page 315. 7. Replace the Engine PCA see EE Box on page 281 8. If the error continues, replace the Touch Control Panel
5/3/2014 10:42:20 AM • HEWLETT-PACKARD... • Answered on May 03, 2014
Printing problem
Please uninstall and re-install the printer software.
3/4/2014 8:15:52 PM • HEWLETT-PACKARD... • Answered on Mar 04, 2014
Yellow & Magenta not printing
Both print heads are clogged, try to clean it manually if not succeeded replace both of them.. U can find how to clean print heads in you tube..https://www.youtube.com/watch?v=Ztl_SiUdPLw
9/17/2013 10:09:37 AM • HEWLETT-PACKARD... • Answered on Sep 17, 2013
Hello, I have a T790 with 60.2:17 error since the
Process 1..1. Switch the power off from the back of the product, wait two minutes, then switch it back on again.2. Check the power cord; try connecting it to another power socket.3. Check that the product is properly connected in all other respects.4. Switch the power off from the back of the product; remove the Formatter; reinsert the Formatter; switch the power on again.Process 2..1. Turn off the product with the Power Key on the left of the Touch Control Panel.2. Press and release the Power Key to turn on the product.3. Wait for about 10 seconds until the 6 buttons on the Touch Control Panel come on and then pressand release one after another the RIGHT -> HOME buttons.4. Wait for the unit to complete the booting process. The logs are now enabled in the product even ifthe product hangs and shows a system error.Once U got the error, check the error related spare, replace it, any help post your query..Formatter snap:620e94e7-860d-4dc4-a3d1-366c50d06553.jpg
9/17/2013 9:53:09 AM • HEWLETT-PACKARD... • Answered on Sep 17, 2013
3answers
"remove roll from sheet path
how to replace pelt plotter hp t790
4/10/2013 6:55:17 PM • HEWLETT-PACKARD... • Answered on Apr 10, 2013
0answers
Color bleeds on edge HP CP4025
Try another cyan toner cartridge. Let me know what happens. Print Quality Troubleshooting Tool for HP Color LaserJet CP4025 CP4525
9/23/2022 8:23:02 AM • HEWLETT-PACKARD... • Answered on Sep 23, 2022
No power when i plug into the wall
Try a different outlet and different power cord.
9/26/2017 6:55:33 PM • HEWLETT-PACKARD... • Answered on Sep 26, 2017
Hp cp1525 has trouble picking up heavier paper from tray
No doubt the feed rollers are worn.
9/22/2017 10:27:22 PM • HEWLETT-PACKARD... • Answered on Sep 22, 2017
0answers
Ink leaks and pools in right back paper tray and leaks onto desk
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
8/2/2017 4:48:27 PM • HEWLETT-PACKARD... • Answered on Aug 02, 2017
0answers
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
21 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
InkJet HEWLETT-PACKARD
  • InkJet HEWLETT-PACKARD
Most Popular Question
  • Office Equipment & Supplies
