20 Most Recent HEWLETT-PACKARD T2300 eMFP InkJet Plotter Printer Questions & Answers
Cke media detect sensor which is mounted inside of cleanout.
clean the sensor or replace the sensor..
1. Remove roller cover upper & roller cover lower
2. Disconnect paper sensor connector
3. Remove clean out (P/no CN727-60047)
4 remove paper sensor..
4e39f03f-171b-4929-bb03-f6046bc6541d.jpg 61e68018-3652-472c-8706-5e97150bb38c.jpg
HEWLETT-PACKARD... | Answered on May 03, 2014
Ensure all consumables are still in warranty period. Ensure firmware is up to date. Disconnect from network and do a power cycle. Check job queue and delete any jobs indicating errors.
HEWLETT-PACKARD... | Answered on Jun 18, 2013
Try a different outlet and different power cord.
HEWLETT-PACKARD... | Answered on Sep 26, 2017
No doubt the feed rollers are worn.
HEWLETT-PACKARD... | Answered on Sep 22, 2017
it sounds like your collection assembly is full. this is not something you can do anything about. it must be replaced and it will be costly. you are probly better off to replace it
HEWLETT-PACKARD... | Answered on Aug 02, 2017
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HEWLETT-PACKARD... | Answered on Mar 01, 2015
Turn off. Reseat the memory. Restart. Error recurs, uodate the firmware
HEWLETT-PACKARD... | Answered on Feb 06, 2015
Should be 1111
HEWLETT-PACKARD... | Answered on Feb 02, 2015
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
HEWLETT-PACKARD... | Answered on Dec 29, 2014
If IT SHOWS the HP LOGO AND NEVER COMPLETE THE INITIALIZATION; it can be FORMATTER BOARD (rplace it), could TRY TO UPDATE THE FIRMWARE AT HP SITE.
HEWLETT-PACKARD... | Answered on Dec 11, 2014
Go to this web site:www.feedroller.com
HEWLETT-PACKARD... | Answered on Nov 30, 2014
Please click An Ink System Error Code Displays on the Front Panel to access the steps that should resolve the issue.
If issue still exists, then the printer need to be serviced.
You need to buy genuine cartridges. Take them back to the dealers and demand genuine cartridges that is if you did not force the cartridges into the slots. If you are printing blank sheets then change toner cartridges.
HEWLETT-PACKARD... | Answered on Nov 20, 2014
I'm assuming you have the correct drivers loaded and correctly configured.
Set power switch to off.
Unplug it for 1 minute.
Plug it back in.
Turn it on.
If it still won't work, I suggest replacing the power supply.
If it still won't work, I suggest you replace it.
HEWLETT-PACKARD... | Answered on Nov 08, 2014
Hi
This printer should have problems with the fuser unit or the power supply
HEWLETT-PACKARD... | Answered on Nov 06, 2014
I hope you have installed the C4480 printer software on your MAC.
click Mac OS v10 6 Snow Leopard No Scan Options or Scan settings are not set... that should help you.
HEWLETT-PACKARD... | Answered on Oct 05, 2014
HEWLETT-PACKARD T2300 eMFP InkJet Plotter Printer Logo
Popular Tags
4 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
elig1000
laulund
Level 1 Expert
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Office Equipment & Supplies
Most Popular Question
solve error 79 2 04 t2300emf
  • Office Equipment & Supplies
