SOURCE: Planar Monitor Wont stay on
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
SOURCE: Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
SOURCE: Planar Pe191m goes dark image seen with flashlight
I would suspect either the power suuply or inverter circuits, look for bad caps first which is common problem, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
If you want replacement lamp, you can look here, it also gives you info on how to measure the lamps dimensions: http://www.lcdparts.net/
