20 Most Recent Planar PE191M 19" Flat Panel LCD Monitor Questions & Answers
try the capasitos in the in line of the circuit they have to be electrolitic condencer some times with the time they open and made the monitor not work try it wiht analog multimeter is more easer know if the condencer are bad
Planar PE191M... | Answered on Mar 22, 2015
Make sure you video cable from the computer is seated in correctly.
Planar PE191M... | Answered on Dec 30, 2012
The monitor cannot support the video resolution that the PC is putting out. You need to lower your PC video resolution or get the better monitor that can support the resolution the game requires.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Planar PE191M... | Answered on Aug 30, 2011
yes
Planar PE191M... | Answered on Mar 21, 2010
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Planar PE191M... | Answered on Dec 16, 2009
plug the screen into another pc, laptop, whatever you can find. if it still does it its the screen, if not its your video. could be a power cord, but usually not. if cheap it may be worth a gamble.
Planar PE191M... | Answered on Aug 23, 2009
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
Planar PE191M... | Answered on Jul 14, 2009
This could be one of two problems, the light in your monitor has a loose cable, or the light is dying. I have seen cold cathode lights that are about 10-15$ to buy and many instructions on putting them in yourself.
Solution 2, your cable is loose on the back of the monitor. Make sure you have the screws tightened on either side of the vga or dvi cable, both on the back of your monitor and on the back of your computer or laptop.
Planar PE191M... | Answered on Jun 28, 2009
Hi...there,
It's seems you got a settings problems. Read your manual again and go over step by step...see which settings you are missed. Make sure the cam are turn on...before you can remote view it.
Planar PE191M... | Answered on Dec 01, 2008
No, there is no microphone listed in the specs, just integrated speakers
Planar Computers... | Answered on Aug 03, 2015
I use either VGA or HDMI connectors to connect to an external monitor.
I'm not sure what you're asking on the "power cord". Are you asking about the charging "brick" and such? Or?
Planar Computers... | Answered on Jun 02, 2015
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
Planar Computers... | Answered on Apr 22, 2015
Planar PE191M 19" Flat Panel LCD Monitor Logo
16 questions posted
Top Planar Computers & Internet Experts
Thomas F. Schneider
William Miller
William Miller
Joe Goldman
Joe Goldman
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Planar Computers & Internet
Most Popular Question
screen goes black after 2 seconds
  • Computers & Internet
