I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it turns to INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
SOURCE: factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
