20 Most Recent
Yamaha HTR-3065 Questions & Answers
What's your problem?how to reset yamaha htr 3065 to factory settings
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.- Leave your remote away as you won't need it- Turn off the the unit to STANDBY mode- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL- Press STRAIGHT button until it turns to INIT **** ALL- Press Power to turn off the machine.- Leave it for 2 sec. then turn on the machine again.Now your unit turns to factory default setting.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
