Without doing anything to my knowledge, my printer now automatically has moved to a 2600 series fax mode instead of the 2600 series print mode that I have been using since I purchased it three years. When I click on print anywhere, HP Photosmart 2600 series fax shows up on the name line. Next to the icon of the machine is a black circle with a white check mark in it. The same circle and check mark appear in printer information in my computer's control panel. I read the owner's manual and followed the instructions to reset the factory defaults. When I reset the defaults, the printer mode I have been using for years is restored, but only for the document that is open and ready to print. When I want to print another document, the fax mode has returned. How can I restore my normal print mode? It is annoying to have to manually change the mode each time. Your assistance will be greatly appreciated
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
