SOURCE: help me
Witch password???
Bios password???
Everex has a known problem with this model of laptop. It has been known to set its bios password by itself. It is a simple fix, but should be done by a proffesional. There is no charge for this repair at a Everex repair center.
If you want, this is what needs to be done. Remove the piece of plastic above the keyboard. Unscrew the 2 screws in the keyboard and lift the keyboard up( No reason to disconnect it ) Unscrew and remove the modem card in the center. There is 2 solder points c88 on the system board. You need to short those 2 points out while you press the power button on. This will reset the bios password. This should take someone about 5 minutes to do.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause
SOURCE: how do log on
Tap the F8 Key contin. until you reach a menu.
use your arrow keys and select safe mode.
once in safe mode go in to control panel, accounts or users and adjust the settings from there.
This works with windows OS.
If you need more help let me know
SOURCE: cant get wireless on my lap top
my everex only hooked up on wireless when it was set up to use wpa password. without router set up with password it wouldn't work. [email protected]
SOURCE: need help about modem driver
You can get the entire driver as well as the user manual from this link
http://www.notebook-driver.com/everex/everex-stepnote-nc1500-notebook-windows-xp-drivers/
SOURCE: need the power jack for the Everex Everex StepNote
you may want to make sure it is not the power cord first, i thought mine was the power cord, I plugged it up to a different laptop and it worked. so it is something in the laptop..
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
