20 Most Recent Everex StepNote NC1502 Notebook Questions & Answers
I have recently formatted my everex stepnote
Hi type in google search Everex stepnote driver download cheers
7/19/2017 8:24:28 AM • Everex StepNote... • Answered on Jul 19, 2017
Lost my adapter (65w), bought a universal laptop adapter but it is rated at 90w. will this work for my everex stepnote nc1502?
Correct voltage Greg?Then yes it will workMore Wattage means more Amperage.Same voltage, but more Amperage(Voltage times Amperage = Wattage )KEEP the inside of your laptop CLEANMake sure you occasionally replace the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset. (GPU)Service Manual for disassembling the laptop?Everex is out of business (To my knowledge), and I see no service manual available.I should be able to step by step you through it, anyway; if you desireRegards,joecoolvette
4/18/2013 9:10:28 AM • Everex StepNote... • Answered on Apr 18, 2013
My computer is slow
If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. To make your computer (hard disk) lean and mean, uninstall any programs you do not use. Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc. This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month. If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
2/7/2013 7:45:29 AM • Everex StepNote... • Answered on Feb 07, 2013
Need to put os on computer
Which version of Windows do you wish to install?Do you have a Windows installation CD and the product installation code?
9/19/2012 7:33:56 AM • Everex StepNote... • Answered on Sep 19, 2012
I need a system recovery disk
need to make one or buy one or borrow one only way to do it
5/23/2012 9:14:36 PM • Everex StepNote... • Answered on May 23, 2012
3answers
Need Everex device drivers
be very carful many sites related to Everex are linked to a bad links and you need to use Firefox to scn them for oyu before you get in...you may find a site soon as I heard that they are trying to get one up next week
9/25/2011 2:40:04 PM • Everex StepNote... • Answered on Sep 25, 2011
Where can I find the recovery disks for a everex
follow this link: http://www.notebook-driver.com/everex/everex-stepnote-nc1502-notebook-windows-xp-drivers/
5/25/2011 3:15:21 PM • Everex StepNote... • Answered on May 25, 2011
Videos play slow or broken
For how long have you been facing this issue ? If it's for a long time then it may be that you no Display driver installed in you Laptop. To check that you have installed the graphic Driver Please right devmgmt.msc As shown in the pic below and check if there is some information available in the Display Adapter ... if it say's default driver etc. Then you must need to install the display driver.
And 2nd: but in Rare case you can increase the resolution of you display setting to maximum and try to playing the movie.
Please rate and vote if you find this solution is helpful and reply back if you need more details or help.
4/21/2011 7:34:28 PM • Everex StepNote... • Answered on Apr 21, 2011
Sound device not available in Everex Stepnote
hello you will find the drivers at the below link goodluck
EVEREX STEPNOTE
3/26/2011 1:28:11 PM • Everex StepNote... • Answered on Mar 26, 2011
Need bios password for Everex
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
3/23/2011 5:21:38 AM • Everex StepNote... • Answered on Mar 23, 2011
Wheer i can download everex
drivers and recovery disk are on ebay
11/14/2010 1:34:44 PM • Everex StepNote... • Answered on Nov 14, 2010
I need to change my screen its broken
I've swapped out literally hundreds of lcds and it's always the same deal.
Remove all the screws from around the lcd outer casing, remove the plastic frame, remove the next row of screws, unplug the lcd cable to the lcd, find the part numbers on the back of the lcd and find an exact match on ebay.
If you search by that part number usually you'll save big time since most people will typically type: nc1502 lcd and the sellers know this so they'll jack up the prices ;)
10/28/2010 2:16:01 AM • Everex StepNote... • Answered on Oct 28, 2010
Laptop will not power up
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
9/23/2010 1:16:40 PM • Everex StepNote... • Answered on Sep 23, 2010
What will happen to a refurbished windows XP
on the pc using safe mode(press F8 when starting) you can access through administrator account and then go to control panel>useraccounts>desired account> remove password and so you can remove the password
9/14/2010 12:19:21 PM • Everex StepNote... • Answered on Sep 14, 2010
HI! I just need the restore disk for StepNote
Technical Support: 1-510-252-8888 (9a-4p Pacific, Mon-Thu) THIS IS THE TECH SUPPORT HOT LINE . ASK THEM TO TRANSFER YOU TO RECOVERY CD LINE . ORDER RUN ENJOY
5/15/2010 4:19:29 PM • Everex StepNote... • Answered on May 15, 2010
HI! I replaced the hard drive in my Step Note and
http://www.myrecoverycds.com/everexSets.html
here
5/15/2010 4:51:33 AM • Everex StepNote... • Answered on May 15, 2010
3answers
Computer appears to be in
For that you need to disable hibernate.
When you power up the computer press F8 key 5 to 6 times then enter in safe mode then go to control panel ->power option ->Hibernate disable it then apply.
If you are unable to enter in safe mode then enter in enable vga mode then change screen resolution to 1024*768 in display property.
Let me know if you need further assistance.
Thanks for using FixYa.
4/19/2010 11:12:30 PM • Everex StepNote... • Answered on Apr 19, 2010
My everex stepnote nc1502 does not stay on
turn off you sleep mode
2/22/2010 8:00:37 AM • Everex StepNote... • Answered on Feb 22, 2010
Everex StepNote NC1502 Notebook Logo
53 questions posted
Top Everex Computers & Internet Experts
k24674
Jose Ramirez
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
StepNote Everex
  • StepNote Everex
Most Popular Question
videos play slow or broken
  • Computers & Internet
