Panasonic DMR-HW120EBK 500GB HDD Recorder with Twin Freeview +HD Tuners (2012) I need the four number pin to update it. the one in the manual is 0000 but i thing someone has changed.
This is the definitive answer from Panasonic Customer Services. It worked for me.
In response to your enquiry, I am writing to inform you that you can reset the PIN number to the default 0000 and then change it, based on your preference. In order to reset the PIN, please follow the next steps:
1. Switch ON the unit;
2. Press and hold the OK, YELLOW and BLUE buttons, at the same time, until you see 00 RET displayed on the unit;
3. Press, repeatedly, the RIGHT ARROW buton until you see 03 VL;
4. Press OK and you should see "INIT" displayed on the unit.
This will reset the PIN number to the 0000 factory preset.
Furthermore, you should also be able to remove the message that is asking you for the child lock PIN while attempting to play back a recording. In order to do this, please follow the next steps:
1. Press SETUP;
2. Choose HDD/USB HDD;
3. Select CHILD LOCK FOR PLAYBACK;
4. Input the default 0000 code;
5. Switch it to OFF.
After performing these steps, the recorder should no longer ask you for the PIN when trying to playback a recording.
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
George
Customer Service Team
Panasonic UK
SOURCE: PANASONIC DMR E85H
Yes you can.
You can get the instruction manual here:
http://service.us.panasonic.com/OPERMANPDF/DMRE85H.PDF
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
SOURCE: Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
SOURCE: Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
SOURCE: I have a Panasonic DMR-EH57
The original HDD will have firmware written on it by Panasonic. When you put a new HDD you might have to go into setup and format the HDD.
