When checking all files in file manager, i can see all the files included in memory stick and phone memory but then when i look for the files for memory stick, it says that no files saved into it..but then i have a lots of files songs and pics saved into it..
what should i do?
should i make a master reset for my k800i cellphone?
how can save or retrieve the files?
is my phone files will be affected if in case i have to reset my phone?
SOURCE: Not able to save pics taken from phone camera
could it be saved in your memory stick? it may also be that the phone memory is full, i suggest you check and if it is not, the you should get the software/firmware check
hope this helps
SOURCE: software corrupted?
Try the following. Leave it to charge for a couple of hours and then try Updating it with Sony Ericsson Update Service from their site using your data cable. If it says you already have the latest software force it to go on. Hope this helps.
SOURCE: trouble with file manager
what you can do is do an upgrade of the firmware on the phone to correct this issue...or take the phone to a mobile center and have it diagnosed.
My main menu occurs a problem that it had no FILE MANAGER, AUDIO PLAYER,CONTACT,ORGANIZER, SETTING & caLLS..
