Sony Handycam CCD-TRV58 Camcorder Logo
Posted on Feb 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tape door won't open or close to release tape
Ladybug
Level 2:
Scholar:
  • Expert 161 Answers
  • Posted on Feb 11, 2013
Ladybug
Expert
Level 2:
Scholar:
Answers
161
Questions
Helped
39020
Points
325
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
1helpful
How to open rear door on 2000 buick lesabre electric door swich won't release
USE A SLIM JIM TO POP THE DOOR RELEASE CATCH FROM THE OUTSIDE, THEN ONCE OPEN, REMOVE THE DOOR CARD & REMOVE & REPLACE THE DOOR SOLENOID
2helpful
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
2answers
Gas door won't open
FIRST: try using the gas release lever from inside the car with the driver side door closed. My 2006 Jetta gas release lever would only work if the driver door were shut and I pulled the release from the inside car interior. Turns out it was a severed door wire (NOT THE RELEASE CABLE). Thus when the door was open, it stretched the damaged wire and so none of the door controls worked unless the door was closed. ie windows, trunk release, and gas release. It was a $600 repair at the dealership, parts and labor! :(
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
Driver's door won't open inside or out. Power locks work but inside and outside handles dont release latch. Can I get door panel off in the closed position, otherwise any way to open door
Hey, You need to remove the panel otherwise u can't reattach the metal sticks that move the locks, but i think it's hard to remove it in a closed posision when u don't brake it
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
