20 Most Recent
Sony Handycam CCD-TRV58 Camcorder Questions & Answers
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder1. Per the manual on esupport.sony.com- if the power is disconnected door won't open, and if the battery is the dead the door won't open.Plug it in and hopefully you can get the tape out.Did this work?
Hola buenas tardes,, Como
Buen d?a, ya que la salida de la video c?mara es anal?gica, es necesario usar un conversor de an?logico a digital, usualmente disponibles como tarjetas de expansi?n PCI o externos tipo USB, la mayor?a de los cuales ya trae un software b?sico para convertir las se?ales digitalizadas al formato requerido para grabarse como archivos, VCD o DVD.
Old Sony Hi 8 DCTVR245E
From my own experience with this, it looks ( or in your case doesn't look no pun intended) like its the shiny inner cassette head that are worn out or defective. That would explain sound and no video. If it is that, and a cleaning doesn't work its not cost effective to continue with that technology
When I turn the camera starts beeping and the on
Yes my friend, relax I like many others have seen this message, it is shouting PLEASE CLEAN MY HEADS, so simply grab a cass head cleaner from your camera shop, put it in camera and let it run for time it tells you on the packet okay?
Good luck take care.
David
I cannot view through my eyepiece anymore only my
You can see if the flex cable came loose from where it plugs into the main board coming from the evf, "electronic view finder" most of the time it is the flex cable itself that requires replacement. You can buy one at Andrews Electronics in California. Larry's Electronics
How do I conect this camera to tv?
http://tv.about.com/od/learningcenter/ss/connectcamtv.htm
try out the link given above, hope this will help you to fix the problem i guess.
please rate this solution...
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Need 2 replace internal battery
compartment located behind lcd. or on the bottom of camera. usually doesnt need replacing though. i guess its not keeping the date and time
