Microwave over the range fmv158f frigidaire it won't shut off after you open the dooor and there is no time left to cook/ you take your stuff out and shut the door
In most cases, it is the door switch. It usually has 2 micro switches and either one can go bad. Not a hard fix. I would look at the operation to see if the switches are working. If that is not it, could be in the circuit board. Could be too much to fix, maybe buy a new one if it is a counter top type. Otherwise let it run till it quits. Call a repair guy, and have him diagnose the problem. Tell him you will fix it in a month or two so could he write down what you need with the part numbers. This way you do not have to start at ground zero. Then order the parts and fix yourself if you feel brave enough.
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
