20 Most Recent Panasonic NN-T888S Convection/Microwave Oven Questions & Answers
WHY DOES THE COVECTION OVEN AND GRILL DOES NOT WORK IN COMBI OVEN
NN-ct559w set on combi micro/ grill function , micro low , grill 1 but grill didnt come one, tried grill on own again no grill . Can thiis be repaired?
10/27/2022 7:25:52 PM • Panasonic... • Answered on Oct 27, 2022
3answers
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
7/29/2021 11:08:30 AM • Panasonic... • Answered on Jul 29, 2021
Hello. My Panasonic NN-K153W microwave owen keypad
Other than a complete power off, I know of no reset switch on any microwave ovens. I own a panasonic myself. I would leave it unplugged for a while, at least 15 minutes or so, and leave the door open, to turn on the inside light (which won't light if unplugged but) so it might discharge any capacitors holding residual power to the circuit. If it wasn't power protected, it could have taken a hit. If it is plugged into a surge protector, they wear out. You might be able to make a claim on it through the surge protector manufacturer, if it has a warranty, and you have receipt. Surge protectors do wear out, and most unless they're the cheapest, will have a warranty that covers equipment. The wear out because the varistor which provides the voltage clamping during a surge become conditioned. Initially they clamp around 150V to 180V, but as they age from repeated surges, their clamping voltage rises until it no longer protects the equipment. Often you can tell, if the surge protector LED is blinking or intermittent, the company will replace the surge device if you make a claim on the protector, if it fails while in use, they usually cover the equipment, unless the warranty has run out, but many give lifetime warranties. The reason some keys may have been working is because after a small surge, the logic states can go indeterminate, which means some work, and some won't. If it's not damaged, a full power off for some time may restore it to initial conditions. Hope this helps. They should build in surge protection, and I think mind does have some; but, if not, I hope it's in warranty for you.
7/4/2017 3:58:18 PM • Panasonic... • Answered on Jul 04, 2017
My Panasonic microwave oven'S digital pad is not showing power when the power switch in on , why ?\
There is a transformer which powers the front panel. Normally attached to the front panel bord. If the transformer is faulty the such problems can occur. If you wish to get some more details about microwave oven repair then check the below added link http://electro-medical.blogspot.com/
7/6/2016 2:53:04 PM • Panasonic... • Answered on Jul 06, 2016
0answers
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and th
Ken, Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
12/16/2014 5:39:54 PM • Panasonic... • Answered on Dec 16, 2014
0answers
THE MIROWAVE FAIL TO WORK BOTH MICRO SWITHES ARE OK ?
I have the same microwave. As far as I can tell the inverter went out to the first one. I now have two and use the first one as spare parts. But that said I tried to use the new inverter in the old oven and is didn't work. so I had to be leave the problem could be the control board.
5/15/2014 5:52:34 PM • Panasonic... • Answered on May 15, 2014
Panasonic NN-T888S will not cook. the power goes on but the try does not spin and nothing heats up
At this time we recommend you use the below link to locate an authorized service center. www.panasonic.com/repair Welcome to Panasonic Online Repair
3/28/2014 1:52:06 PM • Panasonic... • Answered on Mar 28, 2014
Inside oven, right side is a small panel that has a hole in it. should it be replaced....Panasonic Dimension 4...if so whats the part called
There's a grating for the interior light, and another panel a little further back for the microwave output of the magnetron. The microwave panel should not have a hole in it. That would probably indicate some kind of magnetron failure. Not user serviceable. Time to visit a competent tech and/or a service facility.
3/6/2014 4:39:20 PM • Panasonic... • Answered on Mar 06, 2014
After many years of good service my Dimension 4 does not microwave. It goes through all the motions but doens not heat the food. the convection and grill functions are working fine. HELP!
Hi Michael, i think something wrong with its high-tension circuit or your magnitron is bad. the minor fault is open of therm stat for protection. or burnt fuse in circuit. regards, nuwan.
1/9/2014 10:00:37 AM • Panasonic... • Answered on Jan 09, 2014
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok. When I bake, there are knocking sound. Please advise.
11/21/2013 9:16:29 AM • Panasonic... • Answered on Nov 21, 2013
Glass turntable broken
microwave should work with out the plate as the plate turning the food is for cooking evenly for warming porpuses there should be no problem
10/19/2013 2:43:10 PM • Panasonic... • Answered on Oct 19, 2013
What is MEMBRANE SWITCH?
A membrane switch is a type of electrical switch. It's often used in kitchen appliances because they have no external moving parts and thus are immune to splashes and dirt. See http://en.wikipedia.org/wiki/Membrane_switch
8/21/2013 7:52:38 PM • Panasonic... • Answered on Aug 21, 2013
Panasonic NN-T888S Convection/Microwave Oven Logo
136 questions posted
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
panasonic dimension 4 microwave
  • Microwave Ovens
