Can I get the info from the Palm??? I had no recent back up!!
SOURCE: Palm Treo 650 charging port loose and will not charge
I had this on mine, it seems to be a wear and tear issue, mine has gone back to Palm for a paid repair as it is out of warranty:-(
Kevan
SOURCE: Palm Z22 will not turn on
Well you can try a trickle charging on the device.Trickle charging is connecting the device to the computer using the USB cable and then let the device get charged using the computer power source, make sure that you charge the device for 6-8 hrs on the computer.
SOURCE: Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
SOURCE: palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: MY PALM CENTRO WILL NOT POWER ON AT ALL. I HAVE
If you still have this problem, try this:
- Remove the battery...
- Locate the data port at the bottom of your unit, you can see the charger port and aside from it, 13 golden contacts. Star counting from the charging port side and locate pins 1 and 8...
- With some sharp pointed tweezers short those two pins and place the battery at the same time; this can be tricky, but believe, it will work on 90% of the cases. Try it 3-4 times (you have nothing to loose), just make sure the contacts are clean and that you are making good contact while making the short...
This is not a permanent solution, but it will give you the chance to make a backup of your stuff...
Nick222
