20 Most Recent Palm Tungsten T3 Handheld Questions & Answers
Hi Tracy,
Palm creates a backup file of your data so you can restore that file as long as you have not tried to sync your calendar again (that would create another backup file that would be blank.
Here is the link to a forum post that explains how to replace the data file with the backup:
Calendar data deleted from Palm Desktop can it be recovered
Palm Tungsten T3... | Answered on Feb 22, 2016
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Palm Tungsten T3... | Answered on Nov 03, 2013
"I was asking a bout the information on the computer not the hand held. I know the battery is dead. I know I should have backed it up but I didn't."
depending on how the address vanished, it may be retrievable and it may not. If the address was deleted then it cannot be retrievable, but if it vanished on it's on, then it maybe somewhere in the computer.
You can try performing a system restore. System restore helps to back date your computer. You could probably back date your computer to the period/time when the addresses were still in the computer. To restore Click Start > All programs > Accessories > System tools > System restore. Your computer will be restarted in the process. After that, try again.
If the above doesn't work, and you are sure the address wasn't deleted from the computer, then it means it has to be somewhere on your hard disk.
Go to "My computer", "Drive C:". Click the "Programs Files", look for a folder relating to the Palm software, look inside the folder and you might find the address there....
I hope the above makes sense to you. And please let me know if you have any more questions concerning this.
Regards.
Palm Tungsten T3... | Answered on May 16, 2011
I would pull the battery and leave it out for 30 seconds, place it back in, turn the unit on, and try again.
Regards,
Matt
Palm Tungsten T3... | Answered on Mar 31, 2011
I am assuming you are using windows and not MAC? Since you have stated you are using MS access file format, it should be PD 6.2. There is no way to convert the file format that I am aware of.
You will need to "clean" uninstall PD 6.2 and install PD 4.1.4e.
Here is the link to PD 4.1.4e
After you install 4.1.4e, create the same username you had on the previous install of PD, close PD, navigate to c-program files-palm and find the username folder. Paste the address.dat file you have into the address folder in the username folder. Open PD and see if the data is there.
Create a new folder on your PC somewhere that is convenient. Name it something like Palm Desktop Data. (If you need help on the export the manual details are here)
Make sure you select all for the range in the export window.
With the data saved in the folder you created, make a copy of that folder and save to a flash drive, cd-rw or external hard drive.
Anytime you make a change in Palm Desktop, export the data that was changed to that folder and save again to the external media.
With this process you can always import the data back into Palm Desktop anytime you have a problem with the data in Palm Desktop or if your computer/hard drive/device crashes.
I hope that helps and I have answered everything.
Dan
Palm Tungsten T3... | Answered on Jan 14, 2011
use pc suite and synchronise the contacts,etc
Palm Tungsten T3... | Answered on Jul 20, 2010
ow!u mustve bust it hard!!! buy a new cell phone
Palm Tungsten T3... | Answered on Mar 28, 2010
I will be writing off the PDA as it is now over three years old and updating to more recent technology. I have not yet made my repalcement choice.
Palm Tungsten T3... | Answered on Jan 30, 2010
With all the updates and new equipment, it's hard to find the right software for Palms anymore...but there is HOPE!
Visit http://www.markspace.com/ ..they've got sync software for just about everything... I'm sure you'll find what you need.
Hey, happy new year!
Hope this is the last problem for you in 09!
Feliz año nuevo!
Palm Tungsten T3... | Answered on Dec 31, 2009
you might need Mark Space software to get then to talk
Palm Tungsten T3... | Answered on Dec 30, 2009
Please use the free chat feature that palm offers. I am not sure of any other way to charge your palm. Here is the link. Scroll to the bottom of the page and you will see Palm Chat. Click on the Chat Now link and follow the instructions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t3/unlocked/supportservices/page_en.html
You might be able to find a charger on Ebay too.
Palm Tungsten T3... | Answered on Nov 19, 2009
You need an adaptor.
http://laptopsforless.stores.yahoo.net/acadforpalpi.html
Palm Tungsten T3... | Answered on Jul 26, 2009
Issue rather seems software related, if Battery issue usually comes up with low battery alert.
A full (Hard) reset can be a good solution to be sure if its Software related. If you do so make sure you have backup of all your data as full reset will set everything to factory default and will erase the personal data
Good Luck
Palm Tungsten T3... | Answered on Jul 15, 2009
Are you synching with cable or bluetooth
Palm Tungsten T3... | Answered on Jul 09, 2009
Palm Tungsten T3 Handheld Logo
85 questions posted
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Tungsten Palm
  • Tungsten Palm
Most Popular Question
hot sync deleted entire calendar both
  • Computers & Internet
