SOURCE: my ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
SOURCE: I have a GE trash compactor I have to hold up the
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
SOURCE: ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
