20 Most Recent
GE 168997 Deep Fryer Questions & Answers
What kind of oil (vegtable or corn oil )
Hi!
Please use blended vegetable oil, pure corn oil, sunflower oil,
soybean oil or grapeseed (canola oil) because these oils have a high
smoke point. Peanut oil is not recommended because it greatly
impacts the flavor.
• Oils should never be mixed when deep frying.
• High heat, water, and burnt food particles break down the oil’s smoke
point.
• Replace oil if you notice:
- Excessive smoking at normal temperatures
- Strong oil discoloration
- A rancid smell
- Excessive foaming around the frying food
Thanks for using FixYa. Do rate the solution as Fixya if found helpful.
Thanks
Rylee
Fryer stopped working
Hey Guys I had the same problem .. Make sure the unit fits into the grooves on the back side .. The Heating element grooves ..There is a reset ,, you have to use a very small pin to do it .. But I believe the problem is what I stated .. Also remember to clean out the oil pan .. If any gung builds up on the elements it will not HEAT up .. We went thru this same problem as you have all stated ..So check the two situations I have stated ...Good Luck
Can oil be reused in a deep fryer
Hi there!Once the oil is saturated, you have to replace it and properly dispose used oil.If you have an oil filtering machine, you can filter used oil to remove impurities with the use of magnesol.Regards.
Fryer wont turn on since I cleaned it
I don't service home models, only commercial products, however I would guess that something got wet somehow? Let it dry out for a few days and even a week or so, and then try it. If not, I would junk it and buy another...SusanREO
