SOURCE: ROLEX OYSTER PREPETUAL HOW DO I ADJUST THE TIME?
Unscrew the crown, pull out the crown fully to the second position. and rotate the crown counter clockwise or clockwise. Push the crown back in and screw down the crown.
SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: clasp on rolex president comes unlatched.
there is a little flange on the clasp that can be bent to make it snap tightly. Most jewelers will do this service for free while you wait.
SOURCE: how do I adjust the date on my Rolex Oyster Date
The stem has 2 settings...the first pull[click] will be for time only. then pul lit harder and it will come out a little farther and you set the day and date.. Christmas or B-Day ...Congratz..
SOURCE: My Daytona Watch: On the back
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
