When you connect the battery and try to turn it one, you can hear the crank but engine wont fire up. This happened after the battery was found with no juice. my buddy tried charging the battery and heard a loud pop. We went to go buy a new battery and connected it. But the machine wont turn on anymore.
SOURCE: my sansa e260 wont turn on or charge
I had the same problem. Place the device into hold and press the menu and mic buttons at the same time. The first time I tried it, I had no response and then I pressed the same buttons again and my e260 came back to life.
After getting my e260 to come on, I updated the firmware and everything has been working.
SOURCE: Vizio 50" Plasma VP50
Hello SuziCanevaro,
This may have been the sound of electrolytic capacitors exploding. I would not suggest plugging the set back in until you can have it checked by a qualified TV technician. If you are skilled in Electronics and would like to work on this yourself, you will need:
The schematic diagram, a multimeter, a signal generator, an oscilloscope, and an isolation transformer.
I hope this helps,
Thank you,
Shuttle83
SOURCE: 1988 Ford E350 with 2 batteries won't start, just clicks
It has to have 2 batteries because it is a diesel engine. Diesels use compression to fire the combustion mixture instead of a spark plug as a gasoline engine does. It has glow plugs that heat the mixture up before starting to help promote this and it has probably twice the compression ratio,therefore it takes alot of amps to start it and that is why you have 2 batteries. No it still only has one solenoid for the starter but it has to use a gear reduction starter instead of a conventional one.
SOURCE: Iphone Battery died now it wont charge or turn on
Hello !
I was in panic attack !!! did everthing and nothing seems to wake up my iphone.
I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!!
How I fix it?
1-unplug it from the wall charger
2- press middle button and startup button, same time
3-when red battery dissapear, plug the charger.
4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!!
GOD BLESS YOU ALL !!!!!!!!
SOURCE: Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Forgot to add--What could have gone wrong or got busted??
