How can i set up my fax
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
There is a terminal block with several phone lines running to different rooms. I can dial out and receive on the phone line connected through the fax. but can not send or receive a fax.
