20 Most Recent
Brother MFC-8840D All-In-One Laser Printer Questions & Answers
Scanner locked brother MFC-7420
The scanner needs to be reset. Turn off the device and then turn it on again.
Please note that when you turn off the MFC's power switch its memory will be cleared. To check whether the MFC has faxes in its memory, click here.
7/31/2021 11:00:23 AM •
Brother...
Answered
on Jul 31, 2021
Machine error 6D
I looked that error "6D" and could not find anything.
Although there is a error 6E that denotes a hardware problem with the machine.
3/27/2014 3:34:04 PM •
Brother...
Answered
on Mar 27, 2014
Brother MFC 8440D
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers. See if the rollers will turn manually, but be careful not to force anything. Another way to get to the whole roller, would be to start making a print, while watching the rollers. As soon as the rollers have turned half way, unplug the printer. Now you can reach the other side and clean that.
There is another way to clean the rollers. Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution. Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine. Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
3/1/2014 5:18:57 PM •
Brother...
Answered
on Mar 01, 2014
Check paper error
Sir/Madam
I Think There is paper jammed in the printer.
Action:
Press button A, open the front cover and remove the jammed media.Make sure that there is no paper jammed in the paper trays.
Or Still Having Brother Printer Problem The Follow Us For On:
Brother Printer Support
1/23/2014 9:26:48 PM •
Brother...
Answered
on Jan 23, 2014
Brother MFC-8840D ghost image
most likely you have a bad drum. it can also be the fuser.
what is the distance between the first word and the duplicate that follows it.
3/8/2013 10:27:19 PM •
Brother...
Answered
on Mar 08, 2013
Toner low message
The only way to clear the toner low i believe is to change the toner.
10/4/2012 10:51:48 PM •
Brother...
Answered
on Oct 04, 2012
How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
8/3/2012 1:16:38 PM •
Brother...
Answered
on Aug 03, 2012
