I need a conversion kit for a Vermont Castings Radiance Model 2240 gas stove. I need to convert it from LP to natural gas. I can't find a conversion kit. Please help. Thanks. Dana
SOURCE: LP Conversion Kit?
I'm looking for the same thing! My kitchen is covered in black soot and the inside of my new oven is BLACK!!!
SOURCE: converting from lp gas to natural gas
just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
SOURCE: converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
SOURCE: Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
