https://www.fixya.com > Forum > Tags > jkexer e1
...jkexer polar 5090 treadmill and its coming up E1 any ideas please 1) You must adjut the speed sensor, clean it, tight the connector very well.see the ...
images
If the E1 error occurs after the belt starts to move for several seconds, the error code means that the system is not picking up the speed of the motor. This pickup comes from a magnet mounted on the front roller pulley and a speed sensor, or a problem with the magnet.Feb 29, 2016
The True600, 700, 725 and 750 seriestreadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
The error messages that may be displayed by the built-in diagnostics are as follows:
E1:INCLINE
This means that the incline is moving when it has not been commanded to.
E1:MINIMUM
This is a minimum incline calibrating error that can be cleared by calibrating the incline.
E1:RANGE
This means the difference between the treadmills zero position and maximum incline is not sufficient.
E1:STALL
This means that the incline is not moving when it has been commanded to.
E2:OVERSPEED
This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
E2:CAL
This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
E3:EEPROM
This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
E5:SENSOR
This error occurs when there is no speed or RPM feedback detected from speed sensor.
The service messages that may be displayed by the built-in maintenance reminders are as follows:
S1:LUBE
This service message displays when it is time for inspection of the deck lubrication system.
S2:CLEAN
This service message displays every 500 miles and is your prompt to clean the treadmill.
S3:MOTOR
This service message displays every 2500 hours and is your prompt to check the motor brushes.
This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
