While I appreciarte the answer above - I need really plain English sicne I looked at the phone and there is no "settings" button there is a menu button but it does not give a call setting except for on and off and I have tried it both ways and still does not show phone #'s coming in. Does any one have a manual for this phone
AT&T 2.4 GHz Corded/ Cordless System 1 487 / 1187While I appreciarte the answer above - I need really plain English sicne I looked at the phone and there is no "settings" button there is a menu button but it does not give a call setting except for on and off and I have tried it both ways and still does not show phone #'s coming in. Does any one have a manual for this phone
You can't post conmments that contain an email address.
Show my caller ID" Press Phone. Press the menu icon. Press Settings. Press More settings. Press Show my caller ID. Press Show number to turn on caller identification. Press Hide number to turn off caller identification. Press the Home key to return to the home screen.
It is my understanding the caller ID feature comes as part of your telephone service and your phone only displays what comes through. So either you changed the subscription which means you dropped the Caller ID feature or your BT plan does not have it anymore. Best to call BT and confirm.
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
You need to make sure you have programmed your area code...check the manual for setting up caller ID. You can search for the manual on line...go to Retrevo.com
I have had the same problem. I spent days trying to find the settings within the phone, until i called my service provider. They got my Caller ID working within minutes.
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
