Sony Cyber-shot DSC-W70 Digital Camera Logo
prasad gurav Posted on Jul 13, 2007
Everytime I take pictures with my dscw70, the pictures will not show. A blurry screen shot with black and white lines... & whenever i start my camera a scrible ,blurry lines apper on the screen .when i took the pic same line apper in photo plz give me a right solution as early as possible.if it can be manually solved then tell me a solution.
A
Anonymous
O i see i had this prob , its condensation/liquid inside the camera , i suggest that you let it dry out , possibly with a hair dryer but DONT LEAVE IT TOO LONG the camera is sensitive so short period of hot air and letting it cool
Right side of screen blurry with lines-TH-42PX75U
Check the site linked below, and compare the screen shots. It has many kind of defective screen-shots to plasma displays. Compare them to that of yours, and make sure about the faulty board or others. http://electronicshelponline.blogspot.com/
How do I change the settings to take pictures in Black & White? Thank you
From the shooting menu, select "Color." You can select "B&W" for black-and-white, or "Sepia" for the old-fashioned brownish look. For full details look in the manual under "Shooting menu." It's on page 32 of the online version of the manual available on the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW70
5helpful
3answers
My pictures and the lcd screen come out blurry and pink, with horizontal lines across I have a Sony CyberShot DSC-T1 Digital Camera with 5 megapixels and 3x optical zoom I got in 2004. When I take...
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
2answers
Black LCD screen everytime i turn my camera on
I've had the same problem for a while now too.
The camera has been useless and Im looking to replace it.
Im sure this problem hasnt got a simple fix and im better off buying a new camera!
Id like to here if someone managed to get it fixed thou ?
Thanks
2answers
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Blurred pictures
I had the same problem. The solution is in the manual but it is not straight forward. You have to set steady shot to auto when the shutter button is pressed half way down. The vibration warning will still show. At this point the camera is sensing low light. The to need to make sure the flash is set to always on. The flash setting for background will not turn the vibration warning off.
1helpful
2answers
Pictures too white and blurry
more detail casio ex-s600 overexpourse
1helpful
2answers
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
