1998 chevy lumina would not start, but then did & now won't
After driving about 10-15 miles (both hwy and city), I stopped, turned off car, returned to car 15- 20 minutes later, it would not start after repeated attempts. It seemed to crank OK (but maybe rough (?)) but would not fire up. 15 minutes later, it started as normal and ran fine the rest of the day or 2. A few days later it started OK the first time that day and I drove a mile or less to the store, turned it off to go inside, and a few minutes later it started again OK. I drove another mile or two and turned it off. 1-1/2 to 2 hours later it would not start. Sounded the same as a few days before, but after waiting it would not start. I tried it again yesterday and then today. It would not start, but it cranks just the same as explained above. What are the chances a new fuel filter will fix it. I bought it March 2004 at a state auction; it was a police car. March 2008 (125,000 miles) replaced the engine, with a used Buick engine that had about 78,000 miles. At that time, also replaced spark plugs and wires, the idle control valve and the air filter. That was 5,000 miles ago. I replaced the air filter in the summer and I got an oil change about 1,000 miles (1 month) ago I have never replaced the fuel filter.
I have the same problem. It just started yesterday. I would turn the ignition and nothing would happen, just the dashboard lights up. I would try it a few times and same thing nothing. I would wait about 5/10 mins and then it cranks right up. I drive where I have to go...no problem. I come back after shutting the car off for a fem minutes to an hour and boom---nothing. It can't be the starter because I replaced it about 4 months ago. It can't be the alternator because I replaced that less than a year ago. What else can it be??I have the same problem. It just started yesterday. I would turn the ignition and nothing would happen, just the dashboard lights up. I would try it a few times and same thing nothing. I would wait about 5/10 mins and then it cranks right up. I drive where I have to go...no problem. I come back after shutting the car off for a fem minutes to an hour and boom---nothing. It can't be the starter because I replaced it about 4 months ago. It can't be the alternator because I replaced that less than a year ago. What else can it be??
AnonymousMar 17, 2014
after driving 25k stop turn engine off.try to restart 20 min later does not start.wait 10 more minutes then starts ok.after driving 25k stop turn engine off.try to restart 20 min later does not start.wait 10 more minutes then starts ok.
You can't post conmments that contain an email address.
she could have the same car with a diferent engine also in fla you would use the a/c all the time millage rating on the window sticker is done by perfect driving conditions with out normal stop and go driving
Do you normally accelerate quickly from stopped? You can increase your cars mileage by cutting down on rapid starts and stops. A comparable Honda Accord Hybrid rated at a higher 25city 37 hwy MPG rating achieves less than 22mpg when driven HARD
this would be a multifunction switch which turn signal switch wipers ect. run through located on steering column under plastic cover.assuming the brake light switch is good see if third brake light works when you press the pedal if so it is deffintly the multi switch.
Compare Fuel Estimates for 2006 Mitsubishi Raider Trucks Here's a comparison of EPA fuel economy ratings among the trucks in the 2006 Mitsubishi Raider lineup. As always, your mileage will very likely differ. 2006 Mitsubishi Raider 2WD 6-cylinder Trucks * 3.7L, 6-speed manual, 16 city / 22 highway * 3.7L, 4-speed automatic, 16 city / 22 highway * 3.7L, 6-speed manual, 16 city / 20 highway
