Sink/diswasher drain plugged. Drain cleared by plummer but the wash cycle is stuck at "47" . The dishwasher engines runs but no washing taking place, no water and the soap dispenser did not open. How do I recycle to beginning washing process or do I need a serevice repair? Called Bosch customer service but it is weekend.
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
SOURCE: I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
SOURCE: Bosch dishwasher continues to run (Model SHX46A02UC)
searched oother sites. some report a circuit board problem where one of the solder joints overheated and burned out of contact. check yours and repair/replace if that is the problem.
if not at least you can rule it out.
SOURCE: My Bosch diswasher water inlet work fine, when the
Hi, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. I have a copy of it at home and I can likely post it later, ( I'm on my iphone presently ) but essentially what it say's is this...Remove the pump fitler ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight or well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visitng "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not, again please let me know. Thanks again and good luck. Macmarkus :)
Testimonial: "Many Thanks! but motor still not running Impeller turning free"
