Toshiba Tecra S1 Notebook Logo
Posted on Jan 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When powering up I get 2 short beeps and one long one.
When powering up my laptop..Toshiba Tecra Si..ModelPT831C-1104L I don't get anything on my screen but instead I get 2 short beeps and one long beep. I replaced the power cord as well as the ram. It started up okay and would work fine. When I shut it down , it shut down okay but later when I went to use it again I started to get the beeps again and no video???
Any suggestions? Is it time to replace the laptop. I bought it used about a year and a half ago and am assuming it is at least four years old or older. Thanks for any help
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on Jan 22, 2009
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422991
Points
3751
The beep code is signifying either improperly seated/ bad ram or improperly seated/ bad video card. Since you replaced the RAM I would say it would be a bad video card. Replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 • Computers & Internet
2answers
1helpful
Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
I had a Thoshiba Tecra A3 Laptop nwhich is not loading OS
When you hear about the long beep it is a RAM problem which is not totally inserted. You need to check the RAM remove and reinsert it again and try to power on.
1helpful
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
No startup
Majority of beep codes mean there's something wrong with the memory modules or a bad motherboard.
Try taking your RAM mods out and snapping them in. If you have 2, try using one at a time. Then you'll know which one is bad.
Here's a doc on how to do that:
http://www.crucial.com/install/sodimm.aspx
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
