I took videos and photos on 29 Aug 2012 which I deleted on 29 Dec 2012 and I further took photos and videos. Now I want to recover those videos and photos deleted.
Have you restored all your videos and
photos back?
In fact, your problem was really similar to
mine. A couple of weeks ago, the data of my Canon digital camera was also
deleted by chance. All my wanted photos were also lost.
So, in order to get them all back, I had
checked many websites and links. And finally, I found a camera data recovery freeware that had eventually retrieved all
my deleted photos back.
So, I recommend it to you and hope it can
also successfully retrieve all your needed data back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
Dont worry, I had the same problem last time, you can follow this digital camera data recovery tutorial that helped me last time to get back deleted photos and videos from Sony DSC camera.
the guide tells in detail steps for how to recover deleted photos and video files from digital camera.
Since your further photos and videos almost certainly overwrote the original photos and videos, you don't have a very good chance of recovering them. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the memory card into a card reader attached to your computer, cross your fingers, and run the program.
SOURCE: Pictures deleted from memory stick duo
If you have access to a computer then download PCInspector for www.convar.com This will recover lost images on media card so long as they not been overwritten. How this works out with a PSP I would not know.
SOURCE: sony cyber-shot DSC-T9
Yes, other way is to format memory stick and format option is in Menu. Format will delete every thing on memory stick and refresh it for new pictures.
SOURCE: How do you delete ALL
You can delete all the images from the Camera using the Format option.
NOTE: Do not connect the Camera to the Computer to format it. It is highly recommended to format the Memory of the Camera by using only the FORMAT option in it.
If the images are stored in the internal Memory/Memory Card:
Press the "MENU" button.
Select the "Setup" option
Then select the either the "Internal Memory tool" or "Memory Stick Tool" to delete the images from Camera.
SOURCE: I need the user manual
You can download from here :
http://www.sony.co.uk/product/dsc-w-series/dsc-w170/tab/manual
Hope this help and if helpful RATE please.
