20 Most Recent
Sony Cyber-shot DSC-W170 Digital Camera Questions & Answers
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Camera keeps loosing the time and date settings.
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
I need the user manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW170
This page has several documents for download. Instruction manual is eighth down under "Manuals."
Cheers!
How to get pictures off sony cyber shot onto computer using usb
When using Windows Operating System on the Computer, follow the steps given below:
Connect the Camera to the Computer using the supplied USB cable. The Computer will recognize the Camera as a removable drive and list in the Windows Explorer. Press the Windows logo on the keyboard along with the "E" key to open the windows explorer. If the Sony Camera is listed in the explorer as a removable drive then double click on it to open and navigate through the files and folders. Open the "DCIM" for images and "MP_Root" for videos. Once the images and videos are visible, right click on the desired file then select copy. Next, paste the selected file on the hard drive of the Computer.
If you want to select all the files at once then press "CTRL+A", to copy, "CTRL+C" and to paste, "CRTL+V".
Importing video files
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
