Goes in protect mode after starting up.
I have a jvc stero and every time that i turn it on ...it show protect and shuts off!
Protect mode is usually caused by a speaker wiring problem. Check the wire connections at each speaker and at the speaker terminals on the back of the main unit, and make sure there aren't any loose strands of wire touching.
SOURCE: Goes into protect mode and shuts off. Any
sounds like another overheating issue these systems are known 4 this if u have this repaired i rem a bigger cooling fan or your stk's mono parts could go again.
If the unit goes into into protection it usually means the amp is blown. It would need to go into a shop for service if the repari is not cost prohibitive
ok.... i turn it on and then shuts off right away. its says "PROTECT"
My JVC HX-C6 I have had for a while, sounds great ,but went to turn it on and it goes into protect mode and shuts down. What is up?
Same thing with mine. Start it uip and it hits protect mode and shuts off. From what I can tell all of the speakers wiring is fine. I unplugged all of the speakers checked the wires and plugged the speakers back in . Nothing different. It still hits protect and shuts down.
Jennifer
HOLA NO HABLO EN INGLES PERO TENGO ESTE PROBLEMA CON MI EQUIPO CUANDO LO ENCIENDO SE APAGA RAPIDAMENTE Y NO SE A QUE SE DEVE
same problem...anyone know how we can fix this..???
tengo el mismo problema,alguien sabe como solucionar este problema...??? mis conexiones de bocinas estan perfectas...
i have disconnected all of the speakers and the system still gose in protect mode. anymore solutions?
checked the speaker wires every things ok still the same any more solutions
