SOURCE: cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
SOURCE: Can't find code for Motorola Starchoice sat.receiver
Hello, I just tried the same thing for about 2 hours on a buddies system. I did find on the internet to try 0000, 0001, 0002, 0003, 0004, to 0007 see if one of these work?
