SOURCE: need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
SOURCE: make nintendo wii multi region
also, if the games you want to play are copied, like $5 games from asia, you will need a modchip to be installed in your console. if they are licensed real copies, you can buy a datel freeloader to make your wii region free
SOURCE: error code 109144 when try to connect to internet via wii console
Error Code: 109144
There was a problem registering the console to the WiiConnect24 service. What to do:
SOURCE: wii connectivity errors
this means that the router is not compatible with wii there is no magical fi for this pandemical problem unfortuantly
SOURCE: how do i connect the wii console to internet
In the main menu of the Wii, with all the channels, "click Wii Options"
Then go to "Wii Settings"
Click on the right arrow and choose internet.
Enter your PIN number then choose "OK"
Then choose "Connection Settings"
Then choose an unused connection.
Then, if your connection's wireless, choose either "Access Point" or "Wi-Fi"
Then choose your connection.
If connection is secured, enter password and choose "OK"
Then choose "Use this connection"
If connection is wired, choose "OK"
Your Wii console should be connected to the internet.
