If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.htmlHope this will help you
Thank you
Don't know model - range temperature feels too low, even though it says 350 (for example) on the thermostat and with the mercury thermometer that I bought to verify. Baked items (cookies, cakes) don't get cooked on the inside, so I leave them in the oven much longer (sometimes 30-45 mins) until they test done inside w/ fork. Outside is dry as a bone and crumbly. Oven temperature hasn't been right since I bought this range in 2005. I bought this model and manufacturer on good report for few service calls from Consumer Guide. I am not hapy with it.
I have a hotpoint rb757oj6wh range that heats too hot..How do you adjust the oven?
My Hotpoint oven (Even after replacing the bottom and top element) still doesn't work right. Like the person before the top of what your baking gets dry and the inside is undercooked. I have tried to set the temp using the knob on the oven, even replacing the thermostat, but nothing works. I'm at a loss
