Whenever i take a picture the flashing red icon of a SD card appears with a little arrow like thing pointing to it. I already have a SD card in it. What does it mean and how do i fix it?
Http://www.olympusamerica.com/files/oima_cckb/XZ-1_Instruction_Manual_EN.pdf
possibly a defective or full SD card.
SOURCE: CF card problem
A slightly similar experience in that a Memory Stick Duo inexplicably set itself to write protect. No matter what I did, I couldn't format it. I was forced to buy another card. If possible, test it with another card or two. If it happens with more than two or three cards, then I would suspect the camera.
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: Olympus 710 flash won't work
have you tried resetting your camera to initial settings. please refer your user manual to reset it
