Compaq (388746-001) (  388746-001) Motherboard Logo
Allen Ives Posted on Jun 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compaq Presario 4400us
The computer originally would not power up. So I purchased the correct power supply and installed it. Now the symptoms are: Plug power cord in power supply and the power comes on immediately with out pushing power button. Only the CPU fan comes on and the power light is red (bad) not Green (good). You can hear the harddrive spin up but nothing else happens. No video. No POST beeps. Nothing. If you push the power button nothing happens. When you Push and hold the power button for more than 4 seconds the Harddrive LED lights solid and the CD drive lights green solid along with power light stays Red and CPU fan stays on. After this if you push the power button the Hardrive and CD LED's go out Power light stays Red and CPU fan stays on. Power can not be turned off except by unplugging Power cord. Anyone see this before. Fried motherboard or CPU?
  • 1 more comment
  • Allen Ives Jun 22, 2007
    Thanks for the reply. I am pretty sure it is not the PS because I tried two of them and they both give the same symptom. And prior to this the computer would reset by itself every two weeks or so. I will see if I can scrounge around for another motherboard and try it.
  • Manuel213 Nov 16, 2007
    same problem here...the current power supply when plugged in only gives off a light hiss, So I replaced power supply with new one and now as soon as I plugg in the power cord cpu fan goes on and cd drive lights up but thats it. Front power button does nothing but flash yellow at the begining. Hard drive spins but there is no boot of any kind. I have to unplugg power cord to turn off. MotherBoard or CPU?? What can I try next?
  • Anonymous Mar 30, 2014
    power brick and xbox both have green lights when i hit the power button it bings and then goes off and the power brick turns red light on
Kevin Shafer
Level 3:
President:
  • Compaq Master 1,314 Answers
  • Posted on Jun 21, 2007
Kevin Shafer
Compaq Master
Level 3:
President:
Answers
1314
Questions
Helped
523211
Points
4446
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
  • Kevin Shafer
    Kevin Shafer Jun 30, 2009
    Then why the bad rating? If you had included that information in your original post, we could have searched for something else.
2helpful
2answers
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
2answers
I need a manual or product number for power supply power supply order #
No you don't. If you think the power supply is bad, then unplug it, unscrew it, and take it to a discount place like Fry's to simply match it. Compaq does not make its own power supplies, so they use generic ones, like everyone else does. The only thing you have to choose is how many watts you need. The original may have been rated too small if it went bad, and you many want one with more power, like 500 watts.
No power indication
please disconnect your battery then insert your charger then on it., if works claim warranty for battery if not please ask your hardware vendor
1helpful
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
1helpful
Power light flashing HP Compaq Presario SR1230NX PC Desktop I powered the unit down; when I tried to powered it up the only reaction is a green led flashing. The led is located in the back close to the...
Sounds like the Power Supply is bad likes its not able to power on itself. Best thing to do, try a different known good power supply and attach it to the motherboard, if you get the same symptom with the machine not powering on then its a bad motherboard. If the machine does power on then you know your original power supply is bad.
2answers
1helpful
Compaq presario notebook computer
Yes it can.
All notebooks that have dual voltage power supplies can be used worldwide. With the correct physical adapter plug, you need not worry about plugging it in, it will automatically detect the 240v three phase power used in the UK and configure itself to supply your laptop with the usual amount of power automatically.
Compaq 4400us windows install fails on errors
Microsoft Windows XP help Windows XP is available in the below versions:. Home Edition - Full / Upgrade ... Computer
Additional information and help with the boot.ini. If multiple operating systems are setup in the boot.ini, as the computer is booting you will ... Microsoft Windows XP Home Edition Microsoft Windows 2000 .
Good Luck, Please dont for get to Vote/Thank You.
Dell installed on compaq
Hi, you have to use the original CD installer for WinXP that came bundled with your Compaq Presario. Reinstalling with the use of that CD will overwrite all previous installtion (from Dell) and should correctly install the drivers as well. Should the CD be not available, you may want to try and call Microsoft Support and relay to them your problem. You may need copies of proof of purchase and other documents and/or the serial number for the WinXP normally printed on a sticker at the side, back (or underneath for a laptop) of the PC. Another way is to purchase a CD installer of WinXP SP2 and go thru the routine of installing it. Hiope this be of some help to you. Good luck.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
