There isn't one. Because it is operated by putting the van into gear, it is probably a function of the BCM from a switch on the gearbox. Check the socket for continuity to ground and also for rust.
Ford Transit (1995 - 2000) - fuse box diagram
Auto Genius
https://www.autogenius.info > ford-transit-1995-2000-...
Jul 14, 2018 - Ford Transit (1995 - 2000) - fuse box diagram. Year of production: 1995, 1996, 1997, 1998, 1999, 2000. Fuse box diagram.
Fuse box diagram Ford Transit 5 and relay with ...
FuseAndRelay.com
https://fuseandrelay.com > ford > transit-5
Description of all fuses and relays in the 5th generation Ford Transit - 1994, 1995, 1996, 1997, 1998, 1999 model years. Locations and box diagrams.
i too have this problem 1998 diesel turbo start fine idle fine but will only rev too exactly 1500 revs then into idle and no response from throttle ,however unlike the other post i have no light that illuminates on dash ,althoughn it dose at ignition on as it should normally do do you think it could also be the throttle controller pot
lite on no power same prob,goes well but no speed 40 k. up hill
all sorted mate ended up bieng the throttle pot replaced it with a very expensive replacement part and all go now thanks TL
