Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My whirlpool washer flashes f35
My whirlpool washer keeps flashing f35 we have to unplug washer and then go to drain and spin cycle and then re do load
  • azulliavon Jan 18, 2009
    I have the same problem with a F35 error code, however, I first get a message "sud" (excessive suds in machine even if I run the CLEAN cycle and re-run without any detergent). I am having a service repairman back for the FOURTH time. I am VERY VERY dissatisfied with the product to date.
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 28, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5037009
Points
35540
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
2answers
Why is my washer stuck in the spin cycle
hi
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
2answers
Error code f35
F35 (on some models)
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
Check if pressure hose is fixed correctly.
Check if the airtrap is not blocked.
Check if the hose is not blocked.
Make sure you are ONLY using HE SOAP!
Correct usage amounts are as follows:
Regular HE SOAP = 2 Tablespoons
2X HE SOAP = 1 Tablespoon
3X HE SOAP = 1 Teaspoon
The information on the soap usage comes directly from Whirlpool Tech Line.
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain
or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
the unit will rest without tumbling, the water will be drained and it will try
to spin or drain again.
If too much detergent was used:
Run through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Unplug washer or disconnect power.
Check wire harness connections to the drain pump, pressure switch,
and Central Control Unit (CCU).
Check/clean drain pump filter of foreign objects.
Plug in washer or reconnect power.
Check drain pump.
Check the pressure switch.
Verify CCU operation by running a Diagnostic Test or any cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
I have a whirlpool deut steam washer Model W10133484A and I got a F35 error
The recommendation is to change this part:
F-35: Analog switch/water level failure.
Item 20
$86
F35
WASH CYCLE)
Check drain pump.
2helpful
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
We keep getting a "suds" code and then an F35 code
? If too much detergent was used: —Run the unit through a Rinse/Spin cycle. —Run a Normal cycle without adding any detergent. This should clear the unit of the excess detergent. 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). 4. Check/clean drain pump filter of foreign objects. 5. Plug in washer or reconnect power. 6. Check drain pump. 7. Check the pressure switch. 8. Verify CCU operation by running a Diagnostic test or any cycle.
1helpful
I start the machine the suds flashes then it goes away and the F35 flashes and nothing happends I tried to use the clean washer cycle and it still comes up F35 then when I try to push the cancel button the...
If this is a steam unit you have a bad analog pressure switch,has been a common issue in those units,Gives an F35 core and sometimes a SUD code.
1helpful
Keeps flashing F35, when unplugged and plugged back in flashes SUD, there is no soap in the machine. When trying to raise / spin or drain or any other cycle keep getting F35 flashing. This is a Kenmore...
F35 Is an electrical fault in the Control Board.
Try setting the machine on off.
Then remove the plug from the wall for 5minutes. this will usually reset the system and get you going if it is only a glitch in the electrical system.
If this fails to remedy the problem then you have what appears to be a failed control board.
The only way to be sure is to have it diagnosed by a hands on tech.
Or risk your money by swapping it out your self.
The problem is that usually when my customers try this, they end up spending part money and then a service call on top of their failed attempt.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
19helpful
2answers
Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
or kinked.
cycle.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
