A couple of month ago the my t started to turn on by itself then move between menu and tv input options, I thought it my be my remote but even when the remote has no batteries it still will do it. Any suggestions?
SOURCE: TV will not turn on
the exact same thing happened to me but there is no red light when the TV is plugged sould i replace it?
SOURCE: RGBPC input showing invalid format after move
There is nothing wrong with the connection, your TV or computer. Just changw the resolution settings under the display properties. Start with the lowest setting 800X600 and move your way up. It will eventually appear.
SOURCE: Volume trouble with 37LG30
well if you want to get rid of he tv i offer to buy it from you
[email protected]
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
SOURCE: TV randomly turns itself off and on
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
After the TV turns on, it will start kind of a cycle going first to the TV menu then the TV Input options where it will select one (I'm not sure if it is random or not) then after a couple of second will go back to the the TV menu.
