20 Most Recent Sony Playstation 3 (40 GB) Console Questions & Answers
What does it mean when my ps3 say my file is corrupted
It usually means that somewhere, the file has lost information that will allow it to be used properly. .jpg pictures are a good example of this. The more times you open a .jpg format, the more information is lost. Many people don't know this.
5/6/2014 2:31:51 PM • Sony Playstation... • Answered on May 06, 2014
Was playing rugby world cup 2011 today when some
Please confirm which of two is at fault. you can connect a DVD using the same RCA jacks, the red and whilte for audio and the yellow for the video. If the TV works then we are clear on the TV or we need to check other inputs on the TV.If so the PSP has encountered and error and it can be due to a memory crash after it was shut down.see if there is an error code or if this PS3 does not boot at all there is an hardware issue.check this link for support: http://us.playstation.com/support/?s=ps3#ps3x
10/29/2011 1:58:03 AM • Sony Playstation... • Answered on Oct 29, 2011
2answers
Red screen on ps3 and
Hi darkstaf,
This is similar to the red light problem but the reason you get a screen is because the GPU has overheated.
You just need to stop the heat build up getting to the main chips and you will be able to play your games again.
To do this you have 2 choices:
Send it in and they will fix it for you although something to bear in mind that it will take 4 weeks and cost you $150 for the fix.
Or you can use a good PS3 Repair guide and fix it yourself.
A word of warning before attempting any home repair solution:
CLICK HERE TO CHECK OUT A FULL REVIEW OF ALL THE PS3 REPAIR GUIDES FIRST
I hope this helps.
3/29/2011 10:47:40 AM • Sony Playstation... • Answered on Mar 29, 2011
Red light flashes
It means The Ps3 needs a new hard drive..have someone that knows how to handle Ps3's to replace it. Good luck :)
3/8/2011 4:51:20 AM • Sony Playstation... • Answered on Mar 08, 2011
I have a old 40GB Playstation 3 that has a
No expert but sounds like your Blue Ray is done, try any other discs in it?
2/27/2011 5:37:49 AM • Sony Playstation... • Answered on Feb 27, 2011
Bought a few Blu ray discs from uk but they don't
Hello, Please get the code here : www.dvdoverseas.com/dvd.htm
www.regionfreedvd.net/
Regards, Jay__Rfgava
2/25/2011 3:33:24 PM • Sony Playstation... • Answered on Feb 25, 2011
I have a old 40GB
My PS is going through the same problem. I called Sony and they were no help. First they'll make you go through steps that are unnecessary. but some crucial ones are these: 1. while PS3 is off with no disk hold power button until you here 2-3 beeps right after another. PS3 should not start. 2. Hold button again until you hear 1 beep and then 1 Double Beep. 3. You will need to plug in your controller via cable. 4. Now say you want to Restore File System. Select Yes. 5. Go through process of how you want it. 6. The next message that pops up says "The Hard Disk's File System is Corrupted an will be restored." 7. Sometime while you were online/gaming you got corrupted data and this is the result. 8. Say ok and let it fix itself. 9. It should be over soon. 10. If its fixed congratulations! if not continue with the list. 11. I tried this with Sony/Playstation and they said theres nothing i can do and to send it in. Heres the information to call them and everything:
Call: 800-345-7669 Just Press 0 on phone to reach a live person.
Tell them you want to send your PS3 for repairs and it cost's $99.00 us. S/H will be paid in the 99 dollars spent. Meanwhile you will have 3-5 Business days to be prepared they will send you a box for you PS3 its cables and Controller.
Good Luck with your PS3!
Sincerely, GameGuru
2/12/2011 8:22:46 AM • Sony Playstation... • Answered on Feb 12, 2011
When I powered up my PS3 today. I had the dreaded
Wow, so many solutions, which one do you choose..
Ok, here is your answer:
Yes, plug in both HDMI and AV cables.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
You should see, in either HDMI or AV, a screen that ask you to 'connect controller and press ps button.'
If you see this menu with AV and not HDMI, then you will have to use AV.
If you do not see this in either TV input, then this is what you have:
Then you have what is commonly known as the "Green light of Death."
It is when your system powers on and acts normally but no display. Your GPU (graphics chip) has cracked or become damaged and will need to be sent in to SONY. You can try a 3rd party technician, but this repair has a very very low success rate.
1/28/2011 5:25:06 AM • Sony Playstation... • Answered on Jan 28, 2011
My ps3 turns on and the light turns green and
If the system turns on but then turns itself off, beeps at you and flashes its lights at you then you have over heated the system. The GPU chip has problem pulled itself away from the board. This will require you to disassemble.......
OR Click here to download repair guide
1/4/2011 6:25:27 AM • Sony Playstation... • Answered on Jan 04, 2011
When I turn on the ps3 the light goes green then 1
Hi this is a very common problem and its to do with the ps3 over heating,
try the following.
leave it off and unplugged for an hour
check all air vents are free from fluff and dust and vac if needed.
make sure the ps3 is not being used whilst its on carpet
make sure the ps3 is not sitting on top of another electrical item such as dvd or sky box as this will cause it to over heat a lot quicker.
make sure its not wedged in a confined space it needs to have plenty of room around it to ensure cool air flow.
unplug all the leads from the back of the ps3 and the telly then plug them all back in, doing this removes any static that may have built up, then switch it on.
if after doing the above it still dont work then this indicates that either the gpu or cpu chip has over heated, if you have any warranty left take it back you need to check on the ps3 web site to see how old your ps3 is as this fault is covered by ps3 warranty for a couple of years but you need to check this.
now as for getting it repaired, well its a bit hit and miss i repair them myself and if it was an xbox 360 then i would say the chance of it working again is pretty high but as its a ps3 then these can be a bit hit and miss if the ps3 has over heated a lot and fried the cpu or gpu chip or both then the cost of repair would not be worth doing as it would be cheaper to buy a second hand ps3 or even a reconditioned one.
its not the kind of repair you can do yourself as you need to know how to test the circuit board to find out if the chips have been damaged.
the only other option you have is selling it for spares, i buy the damaged ones for spare parts but you wont get much for it as it is, i mean you could pay for the repair and you may get charged even though it cant be fixed,
i always say to my customers that if i cant repair it i will only charge for the parts i used which is nothing but if i do fix it then i charge them the cost of the repair, usually if its beyond repair they let me buy it off them as i pay more than they would get from ebay as they sell on their for about 30 quid with the problem you have got.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
..0.
10/31/2010 10:10:56 PM • Sony Playstation... • Answered on Oct 31, 2010
What is the primary reason the ps3 gets a flashing
Hardware failure. Usually it's because the system has overheated.
10/28/2010 1:17:30 AM • Sony Playstation... • Answered on Oct 28, 2010
Ps3 won't read discs
PS3 won't read discs you need to fix, clean or replace the bluray drive. Learn the step-by-step way to fix your PS3 and bluray drive is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
10/22/2010 4:38:58 PM • Sony Playstation... • Answered on Oct 22, 2010
I cant connect to the psn with the ethernet cable
PS3 Error 80023017 & 8002F0C1 & 8002f14e
Following on from the PS3 3.50 firmware update today, we have started to hear of owners having problems logging on to their accounts.
We have heard of PS3 owners who have updated their system complaining that they cannot sign in, and every time they enter their password are getting the wrong password message. We have had customers who have two PSN accounts and cannot log into either of them. They are met with wrong password message, and even when they use "Forgot your Password" all that comes up is an error.
Conrad Zimmerman of Destructtoid is reporting that PSN is going to have some scheduled maintenance today. This could be why users are complaining of problems logging on to their accounts.
The maintenance is expected to take place during 8 am until 5pm Pacific time. There will be a lot of users who are at work during this time so it will not be a problem for them, but for everyone else it will be somewhat of an annoyance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
9/21/2010 10:17:31 PM • Sony Playstation... • Answered on Sep 21, 2010
Sony Playstation 3 (40 GB) Console Logo
46 questions posted
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
PlayStation Sony
  • PlayStation Sony
Most Popular Question
need new blu ray disc drive anyone know
  • Video Game Consoles & Games
