Sir i am getting a problem in pendrive with iStar.exe application as security it is asking password i forgot my password please helpme my mail id
SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
This seems to be the problem of most of us
these days and some of our readers who wanted to know the methods how
they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without
this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“.
Dont worry, partitioning a pen drive means allocating it its File
System and Cluster Size that was lost after the Low Level Format.
For that:
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
SOURCE: sir good after. I have
Go start menu then click run and type regedit then ok.
HKEY_LOCAL_MACHINES/SYSTEMS/current control set/control/storage device policies.
note:if storage device policies key does not exist then download add.bat file and double click it. After double click it is added automatically to registry.
Double click the write protect in the right pane and set the value to 0 in the value data box and press ok button.
restart your computer and again reconnect the pen drive on your computer.
SOURCE: i forgot my micro SD sandisk 2GB memory card password
For Nokia s60 1st and 2nd edition phones.
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
For Nokia S60 3rd Phones, Nokia N-Series and Nokia E-Series
There is almost no way yet known to hack the memory card password in
case of these types of phone but there is a way to do it some of the s60
3rd edition phones and almost all the E-series phones.
The remote lock option in E-Series phone allws you
to unlock your phone by sending a sms.
The only thing you have to do is to activate this
feature by going to Tools | Settings | Security | Phone and SIM |
Allow remote lock menu. The password of your memory card will
be your remote lock message.
So you have to just send a sms containing your remote lock message
that will automatically change your memory card passsword.
