AT&T High Speed DSL Modem Logo
Posted on Jan 14, 2009
1st time installation: cannot install modem properly
All the lights are green except the "internet" light, which is red. When I try to configure modem anyway, it says that the modem configuration failed.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1122
Points
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
3helpful
UNABLE TO CONNECT WITH MY LAP TOP ON INTERNET HAVE FOUR LIGHTS ON AND FIFTH ONE FLASHING JUST STARTED YESTERDAY.
So that means its working well and connected to the ISP' server. What is your connection? Is it ADSL?
First make sure that all light have the color of green. If they are Flashing with color RED that means the property associated with the light is having a failure.
Here are the description of Colors and Lights.
Modem Light state: Unlit Flashing Red Flashing Green Steady Green
Cases:::
Power Light
Modem is not getting power - no light Modem has failed POST - Red Power is on - Steady Green
Ethernet (2nd Light)
No Ethernet link detected - No light Problem with ethernet port or cable - Flashing Green Modem has detected a successful link to a PC or router - Steady Green
DSL (3rd light)
ADSL sync signal is not detected - Red Modem is trying to synchronize. - Flashing Green Modem has ADSL sync and is ready for PPPoE session traffic - Steady Green.
Internet (4th light)
Modem has given up or isn't configured to initiate the PPPoE session - No Light PPPoE initiation has failed or PPPoE has been terminated. - Red Initiating a PPPoE session to Internet - Flashing Green. Modem is ready for Internet traffic - Steady Green.
Note: This light sometimes not working even if the connection initiated.
Activity
Normal DSL traffic flow - Flashing Green. Steady traffic flow - Steady Green.
Solving problems.
Case1: You have to connect your machine to the Modem Via the Network cable. Plug the other side of the cable to your Machine. (Not the modem port. Network card port.). Case2: You have to make sure that you have installed the Network Card drives. To check that you have to use Device Manager. Follow these steps. Hit Windows key with R In the "Run" box type devmgmt.msc In the right hand side check whether the network card is installed. If it has a yellow exclamation mark or a mark with red that means you haven't either installed or its having a device/driver problem.
Case3: If its fine then what you have to do is to check your network settings. Heres how: Since you haven't specified the Operating System I m including the Windows XP method here. Not much difference in other Operating Systems as well.
  • Get the Control Panel.
  • Go to Network and Internet Connections.
  • Go to Network Connections.
  • Check the Local Area Connection.
  • Right Click and check "Status".
  • If it says connected
  • Check the Duration and Speed(100 or 1000Mbps).
  • If the settings are fine go to "Support" Tab.
  • Check whether the Machine has received an IP Address. Which is often in the range of 192.168.254.xxx for Siemens Modems/Routers.
  • If you see an IP Address which starts from 169.xxx.xxx.xxx your network card was unable to pick an IP Address from the DHCP router which runs in the modem. (If you run a DHCP in the machine you have to configure to stop leasing IP Addresses to your machine from the Router/Modem. You can try the "Repair" button below and it will try to Release and Renew your IP. If it fail either you have a problem with your network card or Modem/Router (Could be the cable also).
  • If you still see the IP Address which starts with 192.168 the connection with your Modem is fine.
  • Next: Right Click on the Local Area Connection again.
  • Go to "Properties".
  • Double Click on "Internet Protocol (TCP/IP).
  • Check the settings.
  • The settings should be "Obtain IP Addresses Automatically" and "Obtain DNS Server Address Automatically". (But if you know the router's/Modem's IP Address you can configure it and you can give a "Static IP" to your PC as well. It must not be the Router's / Modem's IP and must be in th SAME SUBNET. If router uses 192.168.254.xxx you can assign it as 192.168.254.2)
  • Then Apply the Settings and go to the "Status" again and then click on "Details".
  • Except Wins Server all others must be populated with values in 192.168 range. Check the "Default Gateway" Setting. Its very important that you have pointed the machines Default Gateway to the Router/Modem.
  • Final Check:
  • Go to the "Internet Protocol (TCP/IP) again and click on "Advanced".
  • Check IP Settings (first tab) too make sure DHCP is enabled on you machine.
  • Go to "Options" tab and Check TCP/IP Filtering. Click on properties and make sure that the Filtering is not enabled. If it enabled make sure your network adapter Permits all routers traffic in to the machine.
By following these options will let you surf the internet.
Check for the behaviors of indicators as well.
Case 3 :Browser settings
In the Internet Explorer go to: Tools -> Internet Options ->Connections -> LAN Settings -> Its fine if any box is not checked. Or you can check the "Automatic Detection".
Last thing is If you have a Firewall or Antivirus Suite Please make sure that you are not blocking adapters and traffic/application. You can try to disable Windows Firewall and check whether it works as well.
Hope this will solve your issue. Please be kind enough to rate the answer with a comment (testimonial) if this helps you to overcome the issue. Feel free to contact us further. Thanks for contacting Fixya
Internet turns red after 10min of restarting and resetting router
Please make sure that the router is properly configured then only the internet light will be green
Talk to your ISP regarding the router configuration
2answers
All the lights on my Westell Model 6100 are green except the internet light is red. What does that mean? Thank you!
The reason why your internet light is red for the westell model 6100 is because it is not yet configure. You need to access the gui of this modem. Enter the username and password for your internet connection. You will get the username and password from your ISP. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
My at&t modem has a red light on "internet" with all other lights green. What needs to be done to make thecred to green?
The reason why your internet light is red for the at&t modem is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new modem.
If the internet light is red, it is not fine. Are you talking to AT&T support?. While on the phone with them, I had to re-add my username and password with IE and then they had to reset my connection and it worked. Give AT&T Internet support a call.
3answers
Red Internet Light on Westell model 6100F
hi rtoffler....
by the way, is the dsl light solid green or red???...and if it's red... the line connection from the server to your modem is doing good...however, you said that the internet light is red because you have not configured your modem properly.... i mean, you need to update the interface of your modem before you can go online....and whether the message said that you're connected to the network when you connect your XBox 360...the only assurance is when you can browse different websites and lets you go online...however, your pc should be in tri core so that it's compatible with your Xox 360 video game,kkk and so that you would not encounter problems and errors in the future,kkk....and by the way...the data light is always blinking esp if you're browsing websites, the faster it'll blink nd it can't go on a solid green light anyways...,,kkk....and i do hope i was able to configure a little to your concern now....and enjoy playing and downloading more and chanllenging and fun games with your Xbox 360k,,,,happy playing games, rtoffler!!!!! and happy new year by the way!!!!...:-D
INERNET LIGHT STAYS RED
The Internet light changing from green to red means that the connection to the net is unstable. There is a possibility that the device is not configured properly or it already is a problem on the device.
You can try to reset the device and reconfigure it. Just make sure to back up your settings so that you can easily reconfigure your former settings. If that does not work, a firmware upgrade can be done to address this concern.
3answers
Speedstresm 5100 modem
check for physical setup between your modem and the wall jack
if u don know how exactly the physical setup is pls contact your isp for help for u to run through the steps
Top AT&T Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
