Sanyo DS20930 20" TV Logo
Mark Martin Posted on Jun 11, 2007
Manual Controls Insufficient
I lost the original remote for my Sanyo DS20930. I have a universal remote that will turn the television on/off and work the volume, but does not control the input select - leaving me in the input 1 position. I don't have the original manual any longer. Does anyone know of a way of manually setting the input selection? Thanks!
  • Anonymous Mar 25, 2014
    So I have to go thru the inputs until it is back to the original one
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 13, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1132
Points
8
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
How do i get to the input channel
Generally there is an input button on the remote. This is assuming you have the original remote that came with your television. Otherwise, there may be a button on the television itself.
If the model number you provided is accurate, this pdf may help
http://www.sanyotv.com/DS20930%20(E)%200169--.pdf
HOW CAN I FIND THE CLOSED CAPTION ON SANYO TV MODEL DS20930
User manual:
http://www.retrevo.com/support/Sanyo-DS20930-TVs-manual/id/17567dj485/t/2/
See page 6 (CAPTION button on the remote) and page 14 on how to use Closed Caption functions.
2helpful
2answers
Digital?
No sorry to dissapoint DS is short for Definition STANDARD ... and is a cheap 20 inch model assigned to category 2 of televisions. To improve its reception you could apply a Digital setop box to it to get all the additional channels seen on a Digital. Probably last longer than most new plasmas and LCD's as this is quite a robust little TV.
Please rate my help++++Thanks for using FIXYA
2helpful
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Turning off Video2 without remote.
HI:Leeray53
THE MEMORY EEPROM WILL BE CHANGED
PROBABILITY IS DAMAGE,
THAT RESET TO DO IT MODE ORIGINAL
FROM LUIS
2answers
Manual Controls Not Sufficient
If you have a "Menu" button on the front panel of your set, then you may be able to change settings from the menu this way. If not then you will have to have the original remote to change settings. Stargazer
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
