Ricoh 6513 Copier Logo
Posted on Jan 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code SC542 on a Ricoh 3245
Can anyone let me know what this error code is?
Thanks.
Anonymous
Level 2:
Novelist:
  • Expert 126 Answers
  • Posted on Jan 12, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
126
Questions
Helped
102157
Points
300
Hello, this code is : Fusing temp. warming-up error. This means that the fuser did not warm-up in the allowed time. Possible causing-- in order; Thermistor bad or out of position,
fuser lamp bad,
thermofuse bad,
BICU board defective,
power supply board bad,
poor fusing unit connection ----check this first if you had the fuser out of the machine.
If you would like to talk, I can see if we can try to reset the code -- sometimes if the machine is to cold at warm-up the code will throw. # 216-701-1591. Thank you.
3answers
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
3helpful
2answers
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
36helpful
3answers
1helpful
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Ricoh 2090 SC542 error
model 2090 richo sc 542 thermistar and hetar mail cancektar parobelam
1helpful
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Hope this helps!
WizardRepair
2helpful
2answers
Ricoh aficio 1022 all-in-one error code sc542
Fusing temperature warm-up error
The fusing temperature does not reach
the standby temperature within 20
seconds after the main switch is turned
on.
• Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Power supply board defective
• Poor connection of the fusing unit
It could need a new thermistor
13helpful
3answers
Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
