The motor works on the driver side window but the belt comes off. Can I just replace the serpentine belt without replacing both motor and the belt?
SOURCE: 1999 dodge durango fan motor replacement
SOURCE: replace serpentine belt on 2004 dodge caravan
Hello
Here is a link for belt replacement
RD
http://www.autozone.com/addVehicleId,2945902/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800b639e
SOURCE: 1999 Dodge Durango driver side window does not roll up nor down.
Remove the door panel and find the window motor Unplug it and using a separate car battery run cables directly to the window motor When you switch the polarity the motor will either bring the window up or down or if noting happened change the window motor and window regulator assembly.
SOURCE: diagram for a serpentine belt replacement for 2000 avenger dodge
HI. i have posted the diagram requested below.
Testimonial: "This was exactly what we needed, Thank you so very much. "
SOURCE: replacing serpentine belt 2002 dodge stratus
Did this on my 2002 Stratus 2.4L. I agree with other poster, you do have to remove the passenger tire and wheel wall to do it, but the tensioner travels clockwise.
Note: I offer this solely as a description of how I accomplished the task on my vehicle. It should not be taken as me advising anyone else in any way on how or whether they manage to repair their own vehicles.
1) Engaged parking brake, loosened lugs on passenger front tire.
2) Jacked-up and placed jack-stand.
3) Removed piece of black under-carriage which surrounds the oil filter and attaches to front bumper. There are at least 10 plastic push-pins to remove and I managed to destroy half of them in the process.
4) Positoned belt over lower pulleys and tensioner (as best as possible) then used a bungee to hold the top end of belt up while I worked under the car.
5) Used a 3/8 ratchet and inserted into square hole attached to the tensioner, disengaged the tensioner (moves clockwise) then used a brace to keep the ratchet handle in that position.
6) From top, removed bungee and finished placing belt over alternator, checked the position of entire belt, reengaged the tensioner, and replaced wall and wheel.
