It
can be any of the car doors not got properly locked or the door is locked but
the switch is not sensing the door locked. Open and close each door again
properly. Or
else its problem with any of switch wiring getting in contact
with alarm wiring causing it to happen. And
last thing alarm connections need to be inspected. It's getting short somewhere
in between. There
are few help links with solutions, to troubleshoot these types of problems.
I suggest going through these links. Click
the link below: ------ ------------------ http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html -------------- http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html ---------------- http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html ------------ http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html ------------ http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html ---------- http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html ----------- These
details will help. Thanks.
Volvo car alarm
keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going
OFF
2009 Toyota Camry: Hood
Switch causing Alarm to go OFF?
Ford Pickup Alarm will not disengage?
Mitsubishi
Diamante: Factory Security Alarm will not go Off
Toyota Avalon Factory Alarm
will go off?
Chevrolet Tahoe Hood open
warning on dash and alarm sounds?
SOURCE: Resseting alarm lockout in 2001 Pontiac Sunfire
turning left and stalling sounds like your power steering pressure switch is bad.as for other problem try unlocking drivers door using the key this should reset the factory alarm. also make sure you didn't miss a wire when reconnecting bat. look for 12gauge red wire near bat. this goes to computer if not connected car will crank but not start.
SOURCE: radio code
there is posably a radio code in the owners manual otherwise i would say that your best bet is to take it in to a "dealer" there is a code on the radio that matches your vin then the company tells them the radio code i hope i helped. and thank you for using fixya
SOURCE: 2005 Pontiac SV6 Montana key fob unlocks doors but will not lock
For the sliding doors you need to clean the contacts, there are 6 or 8 on both sides, just wipe them clean as they are probably covered in oil/grease/grime.
Dec 2009.
I also have a 2006 sv6 witht he exact same problem. The battery diesd in the remote and after changing it only sets off the alarm now instead of starting? Di dyou figure out the problem?
SOURCE: Anti-lock of radio in Pontiac Montana van
yeah i have the same problem with my bonneville. so your saying theres know way we can reset the stereo
