My laptop beeps with no end and says media test failure EXE and cable failure and says press a key. When i pressed a key it did the same thing and such and such and it doesn't seem to work. What can i do to fix this?
I had that and one of my ram modules was finished. Take it apart as much as you can and check everything is firmly in place. you can get new ram but it may not be ram it could be anything loose cable failure is the clue. As laptopps get bounced a lot you could well be lucky. Remove battery and power and take your jewelry off I use disposable gloves so I dont cause any shorts. While you are in there give your fan a clean. good luck.
