I need to know how to connect a lowrance hds 7 gen 2 to a Lowrance LGC 2000 anenta
SOURCE: Lowrance LCX-15MT Ihave used this
Go to lowrance's website and run through their set up tutorial / instructions for the unit, there is also a software upgrade you can do online for the unit.
SOURCE: Power to Lowrance GPS
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
